Brief Description: Left wing leading edge part #13
Second entry of the day.
After leak testing the tank, I placed it on the spar and screwed every second hole. The joint on the top of the wing is excellent. The bottom at the leading edge joint will need a slight adjustment, but overall much better than the right wing initially..
Also received a couple of things in the mail today.
